dl42
May 29, 2021Aspirant
Guest Network
RBK13 setup running in AP mode.
I have just noted that the option under guest network "Allow guests to see each other and access my local network" is selected and grayed out so cannot be changed. When did this change occur as I know for certain I had deselected this (otherwise its not a guest network is it!) and the option was working properly a while back i.e. guests could not see anything else on the network. I think this must have changed during a firmware update at some point. I have just done a factory reset and the option is still grayed out. Currently on V2.6.2.104. Anyone shed any light on this?
Possible they removed support for Guest Network in AP mode.
Orbi isn't listed here but for most AP mode seen in routers, GN isn't supported:
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
- dl42Aspirant
It definitely worked with previous versions of firmware in AP mode as I checked it. t was one of the main features I was looking for. I had tried a number of other vendor routers/AP who claimed to have guest network capability but clearly didnt once tested. I was pleasantly surprised that the RBK13 did have it and it worked.
I'm going to try and find when it stopped working!
Try downgrading FW to last working version then.
Something to discuss with NG support and see. They don't tell us when features are added or removed.
