TIWIENT
Mar 01, 2022Aspirant
Guest network
Hi, can I have additional separate login aside from the Main ORBI and ORBI Guest-Network? I would like to manage how many gb can each of my staff use, any help greatly appreciated, thank you
Mar 02, 2022Guru - Experienced User
KevinLiT Tough to know what orbi to recommend off such limited data from the OP. The 50 or 80 series pro might be better depending on the users needs. I'd hate to recommend an orbi pro that didn't meet their needs.
TIWIENT What sized space are you trying to cover? How many devices do you need to support? Are you planning on using a wired backhaul or wireless backhaul. What current orbi do you have and is it providing adequate coverage and speeds?
TIWIENT
Mar 02, 2022Aspirant
Hi, thank you for your reply, I know this is a support group and really appreciate everyone's comments, I have Orbi 4GX AC1200 Dual-Band Mesh Model LBR1020. I'm just a little frustrated as there is no manual you can read on. Although the app is good but for someone not too technical, I have to play around it to get it going. It's definetely not the model I need, sad about it. Thank you again all so much.
- plemansMar 03, 2022Guru - Experienced User
