hyperman27
Jan 16, 2024Aspirant
Guest network
I would like to create a guest wifi network on my RBR50. When I go to sign into http://orbilogin.com it says the connection is not secure?
Jan 16, 2024Guru - Experienced User
Just select continue or allow and add this site in the browser.
Try using a different browser, MS Edge, Firefox or Opera will do.
- hyperman27Jan 16, 2024Aspirant
Can I do this in the Orbi app instead of the website? When I enable the guest wifi in the app it will not let me crate a password
- FURRYe38Jan 16, 2024Guru - Experienced User
You'll need to use the web UI to get it setup.
