hyperman27
Jan 16, 2024Aspirant
Guest network
I would like to create a guest wifi network on my RBR50. When I go to sign into http://orbilogin.com it says the connection is not secure?
hyperman27
Can I do this in the Orbi app instead of the website? When I enable the guest wifi in the app it will not let me crate a password
Jan 16, 2024Guru - Experienced User
You'll need to use the web UI to get it setup.
