JoelVanOrmeling
Jan 28, 2019Follower
guest wifi not enabled but it is available...
On the ios app my guest wifi is NOT enabled... (Orbi rbr50)
but unfortunately the network is showing and is accessible...
Do you have the broadcast check box checked? Uncheck this box, save settings and reboot the satellite(s) and router then check for the GN SSID name.
Do you need Guest Network enabled?
- ekhalilMaster
Enabling and Disabling of the Guest Network need a reboot to make the changes take place.
