cserrano7's avatar
cserrano7
Follower
Mar 25, 2018
Guest WiFi Orbi
What is the guest WiFi setting for on theOrbi app?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Its so you can enable or disable the guest network on your Orbi router.
    DarrenM
