XBond
Jul 19, 2021Apprentice
Guest WiFi randomly drops Internet connection
I have 2 RBS50s and 1 RBR50. My setup has been running flawlessly for years, as in no issues. Recently (last month), the Guest WiFi randomly drops the Internet connection. The WiFi is there, but ...
- Jul 19, 2021
there is a newer 2.7.3.22 firmware out there
Have you tried it?
XBond
No, hadn't seen that update.
The notes say this -
- Fixes the DNS query failure issue that occurs when traffic meter and daylight saving are enabled
But I had both turned off.
Jul 19, 2021Guru - Experienced User
Always worth a shot.
I'd try updating, then do a factory reset and reinstall.
Sometimes old settings have caused issues as well.
