XBond
Jul 19, 2021Apprentice
Guest WiFi randomly drops Internet connection
I have 2 RBS50s and 1 RBR50. My setup has been running flawlessly for years, as in no issues. Recently (last month), the Guest WiFi randomly drops the Internet connection. The WiFi is there, but ...
- Jul 19, 2021
there is a newer 2.7.3.22 firmware out there
Have you tried it?
AstroCat
Jul 21, 2021Star
We've also noticed unstable Guest network issues, like you describe. Main network totally solid. FW: V2.7.2.104
How'd the reset go? Any better?
XBond
Jul 21, 2021Apprentice
I upgraded to the FW version mentioned above and so far so good. But that does not mean the issue is fixed. Usually I would turn the guest network off/on and it would work fine for some random amount of time. Sometimes a day, sometimes several. Same if I restarted the router/satellites.
So I am not holding my breath here.
- AstroCatJul 21, 2021Star
Fair enough, I upgraded as well. Let's see how it goes. Thanks.
- AstroCatAug 20, 2021Star
Yeah, Guest network is now pretty much unusable. People can connect but website loads insanely slow or time out. It's just really unstable. The normal network is 100% solid, only the Guest network is a mess. Any way to fix this? It wasn't always like this.
FW: V2.7.3.22
Router RBR50 RBR50 V2.7.3.22 No new firmware version available. Satellite RBS50 ACOrbi Satellite-1 V2.7.3.22 No new firmware version available. Satellite RBS50 ACOrbi Satellite-2 V2.7.3.22 No new firmware version available. Satellite RBS50 ACOrbi Satellite-3 V2.7.3.22 No new firmware version available. - FURRYe38Aug 21, 2021Guru - Experienced User
FW: V2.7.3.22
