geris's avatar
geris
Follower
May 22, 2020
Guest WiFi Works, Main WiFi network disconnects
I cant work this one out, I have tried latest firmware and rolled back the last 5 versions of firmware.  Guest WiFi works perfectly, Main Network drops out constantly.
I have tried just with the router and no satellites, the same issue occurs.  I have tried different channels.
Has anyone seen this problem before?
  • Has a factory reset and setup from scratch been performed since last update?
    Using this version of FW?
    https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/true#M89460
    You may need to contact NG support and ask about a RMA if nothing seems to correct the problem.
    • bioclotidtai's avatar
      bioclotidtai
      My neatgear ac1750 is working fine from 2017 I bought from amazon for $100, it has dual-band that works simmultaneously, even the app Nighthawk works fine. Only problem encountered is provider -> modem -> netgear router to give wi-fi!...
      • FURRYe38's avatar
        Guru
        What model NG product are you referring to?
        This forum is for Orbi AC series MESH wifi systems.
