Arifturzo09
Jun 04, 2017Follower
Guest Wifi
I am unable to turn on guest wifi through genie app it is showing that router doesn't support guest wifi. I have orbi RBR 50 Also Guest wifi didn't disable while requesting to Alexa
DarrenM
Jun 05, 2017Sr. NETGEAR Moderator
Hello Arifturzo09
Are you able to log into the web page www.orbilogin.com and then change the guest network settings?
DarrenM
