Arifturzo09
Jun 04, 2017Follower
Guest Wifi
I am unable to turn on guest wifi through genie app it is showing that router doesn't support guest wifi. I have orbi RBR 50 Also Guest wifi didn't disable while requesting to Alexa
DavidLego
Jun 06, 2017Initiate
Re the Genie Ap and not recognising guest wifi on the Orbi router. Netgear support have said that this is a known problem that they are working on.
So currently you have to use the Orbilogin to set it up.
Hopefully the Ap functionality will be there soon.
