Stuartofmt's avatar
Stuartofmt
Guest WiFIi Enhancements
I moved to Orbi having had a short fling with Google WiFi.  I did not like the administration through the cloud which did not work that well (or at all).  One thing that was near perfect on Google was the guest WiFi.   I find the current guest wifi on Orbi to be borderline at best.
Here is what Google allowed:  you can set up some (or all) of your devices on the main network.  You can set up a guest network .  You can then - selectively expose devices on the main network to the guest network.  These devices are then visible from BOTH networks.
This is especially useful for devices like Sonos or Printers.  With Google WiFi (and other routers)  - my houshold had access to these devices and so did guests.  Sadly not with Orbi.
Orbi should provide this level of flexibility.
  • tbh i dont even know how thats possible as you cant be connected to both the normal ssid and guest ssid at the same time as its would cause all sorts of issues with the router seeing the same mac address twice , you may be explaining it differently to what im understanding here however
    • aaz's avatar
      aaz
      Virtuoso
      Pretty sure that last part...
      He did not say that the Sono's would be connected to both guest and regular WiFi only that guests could use the Sonos that is on his regular network. It's not a common guest Wifi feature but I could see the uses for it. Instead of exposing your devices publickly, it's like a DMZ for guest access.
    • st_shaw's avatar
      st_shaw
      Master
      What the OP described is easily accomplished on other routers with VLANs and firewall rules.  You put the regular and guest networks on separate VLANs and use firewall rules to allow guest access to certain devices.
      • we arnt talking about vlans here , we are talking about wifi connectivity and you cant join 2 ssid's at once
