tmaybe
Oct 09, 2020Follower
hacked wifi network
My data usage has gone through the roof and I've been told my network was likely hacked. I changed the network password and the data usage went down to "normal" for a month and this month it is exce...
Oct 09, 2020Guru - Experienced User
I think you can check the system logs under Administration, it will list connected devices with IP address and MAC address so you'll have to narrow down what devices are online and you can get physical access too check this against what you see. Also look at the connected clients list on the RBRs web page as well.
