tmaybe
Oct 09, 2020Follower
hacked wifi network
My data usage has gone through the roof and I've been told my network was likely hacked. I changed the network password and the data usage went down to "normal" for a month and this month it is exce...
Mikey94025
Oct 09, 2020Hero
tmaybe wrote:My data usage has gone through the roof and I've been told my network was likely hacked. I changed the network password and the data usage went down to "normal" for a month and this month it is excessive again. Is there a way to see a log as to who logs onto my network?
It seems very unlikely to me that your home network is hacked and especially if you changed your wireless network that it would happen again. How much data usage are you talking about? Was the ISP support just guessing or did they look at actual data to determine that you were hacked? Do you have any Nest or other always-on wireless cameras (these use quite a bit of bandwidth, especially if you don't ratchet down their quality level)?
Alternatively, you may have rogue devices that are using much more bandwidth than you expect. Review all of the connected devices via the Orbi's list of connected devices. For phones, check their reports of network usage to verify that they aren't doing a lot overnight or something.
