davetsla
Apr 29, 2019Aspirant
Haiku L fan won't connect
There was a topic on this before but was marked as solved by downgrading to a 2018 version of firmware. I called Haiku and they said the Orbi system is one of the few wifi systems their fans won't co...
Apr 29, 2019Guru - Experienced User
What firmware is currently loaded? v48 is most current.
You can try to temporarily disable the 5Ghz SSID broadcast, leaving the 2.4Ghz only running to see if the fan will connect.
davetsla wrote:
There was a topic on this before but was marked as solved by downgrading to a 2018 version of firmware. I called Haiku and they said the Orbi system is one of the few wifi systems their fans won't connect to. I can see the fan on my wifi network but it won't keep connection. Any new updates? Thanks.
- davetslaApr 29, 2019Aspirant
Thanks. Sorry, forgot the firmware version. I have the latest .48 firmware. I do have the 5Ghz also being broadcast so can try that.
