golfgeek's avatar
golfgeek
Initiate
May 28, 2020
Handling Orbi Router Issues after Power Outage
Sharing this to hopefully help someone else, as well as welcoming comments from experts out there.   I had an extended power outage (7 hours), with some brown outs/false starts, and when things cam...
  • michaelkenward's avatar
    May 29, 2020
    Before jumping through any hoops to sort out a network after a power cut, the first move has to be to restart everything systematically and in the correct order. Don't just leave them to reboot in random order.
    Turn off everything, then restart things on the correct order: modem (wait until it is ready) > router (wait until it is ready) > satellites and other network infrastructure and then other devices such as PCs, NSAs, etc.
    In that way, they will get their addresses in the right order, with less risk of confusion and duplication.
    You can also make life easier by reserving IP addresses for devices so that they always get the same address.
