Net56's avatar
Net56
Hard-set Orbi Channel Width
Hey everyone, I want to manually restrict Orbi's 2.4 and 5 GHz broadcasts to 20 MHz wide for selected center channels.   I am aware of the default "Enable 20/40 MHz co-existance" option for the 2.4...
  • Mstrbig's avatar
    Oct 05, 2020
    The answer is no. However, depending on what PC, Laptop, etc you have, you can force what frequency you want to connect at. My Dell laptop allows me to force connect either 20Mhz or 40Mhz on 2.4Ghz and 80Mhz only on 5Ghz.
