Net56
Oct 05, 2020Aspirant
Hard-set Orbi Channel Width
Hey everyone, I want to manually restrict Orbi's 2.4 and 5 GHz broadcasts to 20 MHz wide for selected center channels. I am aware of the default "Enable 20/40 MHz co-existance" option for the 2.4...
- Oct 05, 2020
The answer is no. However, depending on what PC, Laptop, etc you have, you can force what frequency you want to connect at. My Dell laptop allows me to force connect either 20Mhz or 40Mhz on 2.4Ghz and 80Mhz only on 5Ghz.
Oct 06, 2020Guru - Experienced User
https://en.wikipedia.org/wiki/List_of_WLAN_channels#United_States
To get a connetion rate of 866Mpbs on the user side of 5Ghz if the wireless device supports that rate, 80Mhz will be needed. Channesl 36 thru 48 do support 80Mhz.
Kind of old but still applies for AC:
https://www.smallnetbuilder.com/wireless/wireless-features/32238-ac1900-innovation-or-3d-wi-fi
