spif91
Aug 27, 2024Aspirant
Hard wire and Orbi RBK13-100NAS
Probably been answered 100’s of times on this forum but I don’t have the time to search for it. I personally have a Google mesh system. My neighbor has an Orbi system. When I built my shop 4 yrs ago I...
Aug 28, 2024Guru - Experienced User
yes. you can add extra satellites with orbi and use a hardwired backhaul
spif91
Aug 29, 2024Aspirant
So a hardwired backhaul is just running Ethernet from a 4 port switch I have connected to my router in the house directly to the single Orbi in my shop and plug it in?
- plemansAug 29, 2024Guru - Experienced User
You're wanting to connect his google system to your orbi system?
I was under the assumption that he was doing the same thing you did- spif91Sep 04, 2024AspirantI went back and reread my post and sorry it was clear as mud. He wants to to do the same with his Orbi system that I did with my Google system at his house. Previous posts it looks like a hardwire backhaul should work for his residence with the Orbi just like it did for me at my residence with the Google WiFi. We aren’t going to connect our 2 different systems which from what posted it made it sound like that. Was in a hurry typing and didn’t make myself clear. Thnx
