RobertV1966
Mar 10, 2019Tutor
Hardware Failure
Hello,
This is more of a buyer beware issue rather than a problem that can be solved using other customer experiences. I purchase an Orbi Router/ Satellite package from Best Buy on January 28, 2019...
CrimpOn
Mar 10, 2019Guru - Experienced User
If the extended warranty was purchased from Best Buy, maybe you can return it to Best Buy for exchange?
- RobertV1966Mar 10, 2019Tutor
Hi CrimpOn,
The extended warranty for the equipment was purchased through Netgear. If I had purchased the extended warranty through Best Buy, I could have simply returned it to the store for an exchange. It would have been much easier doing it that way. Lesson learned here.
