TonyLehner
Jan 09, 2021Follower
Hardwire a satellite RBS50
Can you hardwire an Orbi satellite RBR50 running V2.5.2.4 directly to the network to increase signal strength? Or do you have to hardwire the router to the satellite? If you did this, not sure wher...
alokeprasad
Jan 10, 2021Mentor
Instructions are here:
Ethernet (wired) capacity is much higher than wireless, so, the wired connecton should always be better. But the difference may not matter if the wifi connection between your router and satellies is strong.
