txbdan
Feb 23, 2019Aspirant
Hardwired download speed slow through Orbi, fast to computer
Hi all,
I have a new Orbi AC3000 (RBR50) and i'm finding that the wired download speeds are slow. I have gigabit FIOS.
Hardwire FIOS ONT directly to 2018 Mac mini using two cat5E cables coupled...
txbdan
Mar 23, 2019Aspirant
I updated to the latest firmware and also tried some various MTU settings suggested by support. No luck so far.
Next time i have a minute i'll factory reset the Orbi and run setup with a computer instead of using the app.
Mar 25, 2019Guru - Experienced User
Please let us know how it goes.
- Stea1thSep 05, 2019Aspirant
Has this been resolved?
I also have FIOS and the max connection I can get with orbi seems to be 550ish down and 950 up...if I bypass orbi get a consistent 900/900.
- FURRYe38Sep 05, 2019Guru - Experienced User
What model Orbi do you have?
Stea1th wrote:Has this been resolved?
- Stea1thSep 05, 2019AspirantRbr 50
Firmware v2.3.5.30
It’s connected to the Verizon ONT directly via cat 6
