belsokary's avatar
belsokary
Hardwired Orbi shows offline satellites.
Hello,   I tried to research this on these forums, but am having a hard time finding an answer.   Hardware List:   - Orbi RBR50 Router, Firmware v2.7.2.102 - Orbi RBS50 (x2), Firmware v2.7.2.1...
  • CrimpOn's avatar
    Dec 28, 2020
    Orbi is designed for the satellites to be "behind" the router.  i.e. connected to the Orbi LAN ports.
    Not connected through the WAN port.
    The correct solution is to connect the gigabit switch to one of the Orbi LAN ports and connect satellites to the switch.
