FFSmasher
Nov 06, 2022Follower
Hardwired Satellite disconnecting daily
Router - RBR40 Firmware - V2.7.4.24 Satellite - RBS20 Firmware - V2.7.4.24 I have a wired backhaul that goes offline almost daily. Sometimes it will take up to 6 restarts before it reconnec...
Nov 06, 2022Guru - Experienced User
1. what modem/gateway is the router connected to?
2. what switch is the backhaul running through? or is it directly wired to the router?
3. do you have more than 1 satellite? is the issue specific to a specific satellite? Or do they all have issues?
