blamman
Jun 15, 2021Apprentice
Hardwired Satellites slower
Hi I have an RBR50 with two satellites. WMM, Beamforming and Mu-Mimo are all enabled and daisy chain disabled. My fiber connection is 300/300 Mbps. I have my satellites wired with a TP-Link TL-SG...
- Jun 17, 2021
It looks like it was the tp link switch. I put an old router in its place with wifi off and speeds are where they should be.
blamman
Jun 16, 2021Apprentice
Thank you. I will test out when I can. All of the cat 6 pass thru cables I crimped around 8 months ago and used a wire tester. I know when I hooked up my laptop onto one of the cables going to the satellite. it did negotiate 1 gig.
