Leex1681
Feb 27, 2021Aspirant
Hardwiring my Satellites
I am not tech wizard and need some help. I purchased the Orbi RBR40 with one router and 2 satellites. The router is hardwired In our basement through our cat5(?) Ethernet? (I think I said that correct...
- Feb 27, 2021If I’m understanding correct, daisy chain is how I have it set up now? Each satellite on different floors not hardwired yet.
So your recommendation would be to hardwire the satellites?
Leex1681
1. Firmware - v2.6.2.104
2. We have a charter/Spectrum modem
3. 200mbps is all I can find on my bill? We have spectrum Internet
4.not sure about the speeds when I hardwire as we have not tried this yet. I was curious to see if it would help to hardwire.
CrimpOn
Feb 27, 2021Guru - Experienced User
plemansis correct that many factors influence performance.
200mb is entirely adequate for Zoom meetings (I have 200mb from Spectrum and we Zoom and Facetime many times a week).
The question about hard wiring was intended to verify that Spectrum is actually delivering 200mb.
When a computer (desktop, laptop) is connected directly to the Spectrum modem with an ethernet cord, that is the highest speed possible.
If this is inconvenient or impractical, then the Orbi Speed Test is an approximation.
The 'backhaul' network is also critical, especially if the satellites are "Daisy Chained". i.e. Floor 2 connects to Main Floor, which connects to Router. That makes two "hops". If this is the problem, then hardwiring both satellites directly to the router will make a huge difference.
Performance over an ethernet backhaul connection will be dramatically better than performance over two WiFi hops.
- CrimpOnFeb 27, 2021Guru - Experienced User
Another consideration is that problems with video chats (Zoom, Facetime) can be caused by factors outside of your WiFi network, such as at the "other end."
- Leex1681Feb 27, 2021AspirantThat’s what I was wondering too but everyone else can hear each other just fine, I just can’t hear them and their video comes through super slow. Like they are talking In slow mo and they hear me in slow mo
- Leex1681Feb 27, 2021AspirantIf I’m understanding correct, daisy chain is how I have it set up now? Each satellite on different floors not hardwired yet.
So your recommendation would be to hardwire the satellites?- CrimpOnFeb 27, 2021Guru - Experienced User
So your recommendation would be to hardwire the satellites?On the Orbi web interface, Attached Devices page, the satellites are listed at the top of the display. The column "Connected Orbi" shows what each satellite is connected to. If one satellite connects to another instead of the router, that is Daisy Chain.
If connecting the satellites directly to the router with ethernet cable is practical, it removes Daisy Chain from being a possible cause of problems. I would wire my satellite with ethernet except that I cannot find a way to place a cable between them. (Damn these two story houses with no crawl space under the floor and no attic access to every room.)
If installing ethernet cables is a major effort, it is possible to test what happens by using temporary ethernet connections.
Amazon sells 100ft. ethernet cables for under $20. The family may tolerate cables running up the stairs, through the hallway, etc. for a couple of hours. Convert to ethernet backhaul and start up a Zoom meeting. Better? install cables. No Better? Not the problem.
- Leex1681Feb 27, 2021AspirantGreat! This helps me understand the setup! Thank you. I will try the Ethernet approach!
Amy
