Tgterm
Jun 25, 2018Guide
Harmony Hub issues since 2.1.4.16? Coincidence?
Hi - not sure if it is coincidence or not, but it seems that since I updated to 2.1.4.16 I have been having difficulty using my Harmony Elite. I plan to call Harmony tonight, but I was wondering if ...
Jun 25, 2018Guru - Experienced User
Was a full power down of the Orbi system for 1 minute then back on?
Any other wifi neighbors near by? If so, how many?
What channels are you using? Try manual 1, 6 or 11 on 2.4ghz.
Disable MIMO, Daisy Chain and Fast Roaming, save settings and reboot the router.
- TgtermJun 25, 2018Guide
Thanks! I did reboot the router, but I guess I could take it and the sats down and restart to see if there is a positive impact.
I guess I wonder why my setting like channels, MIMO, and Fast roaming would suddenly matter (already have Daisy Chain disabled as I don't think I need it). I have had these set as they are with the Harmony working fine until now. Weird.
- FURRYe38Jun 25, 2018Guru - Experienced User
Anything is possible with these systems and new FW coming out. I know. Just trying to help figure it out.
Could be channels and other users near by with wifi. Could be a change in your surrounding environment as well.
Agreed. I will try as you suggest and hope for the best...appreciate the input.
