Tgterm
Jun 25, 2018Guide
Harmony Hub issues since 2.1.4.16? Coincidence?
Hi - not sure if it is coincidence or not, but it seems that since I updated to 2.1.4.16 I have been having difficulty using my Harmony Elite. I plan to call Harmony tonight, but I was wondering if ...
mactenchi
Aug 14, 2018Aspirant
I've been having the same problems since updating also.
- FURRYe38Aug 15, 2018Guru - Experienced User
Was a full power down of the Orbi system for 1 minute then back on?
Any other wifi neighbors near by? If so, how many?
What channels are you using? Try manual 1, 6 or 11 on 2.4ghz.
Disable MIMO, Daisy Chain and Fast Roaming, save settings and reboot the router.
Try a factory reset on the Orbi system then setup from scratch as a last resort...
