gmhaynes
Jul 27, 2018Aspirant
Harmony Hub Issues
In the last month or so, I moved into a new home and set up a component cabinet on the main floor with two Sonos Connect AMPs on top shelf, DirecTV Genie, SmartThings Hubs and Harmony Hub on middle s...
gmhaynes
What FW are you using? 2.1.4.16
Was a full power down of the Orbi system for 1 minute then back on if you updated FW? I can't say for sure.
Any other wifi neighbors near by? If so, how many? Just a few and I have checked channel usage. See below.
What channels are you using? Try manual 1, 6 or 11 on 2.4ghz. 2.4ghz set to Channel 1. Not a lot of neighbors, but 1 was definitely the least used. SonosNet using Channel 11. Zigbee (SmartThings Hub) using Channel 20.
Disable MIMO, Daisy Chain and Fast Roaming, save settings and reboot the router. Daisy Chain is disabled. MIMO and Fast Roaming are not, nor his implicit beamforming. I am willing to try disabling any/all of those three features if you believe they could fix this Harmony issue. When you say "reboot the router", is there a specific process for that or can I just power cycle it?
It definitely seems like the Harmony does not like mesh systems, especially with Logitech support quick to recommend connecting a separate router as AP with only 2.4ghz band enabled. I have seen others suggest enabling the Orbi Guest Network to use for 2.4 ghz hubs. Any thoughts on that?
I did reach out via private message to Tgterm and unfortunately he is still having issues. He believes it is an RF issue between Remote/Hub, but I am not so sure that is the case because his issues are very similar to mine and I know that mine are WiFi related.
Thanks again for your help.
Jeremyinsf
Jul 27, 2018Apprentice
My Harmony Hubs (I have two) work fine with the my Orbi system in general - Until I throw my Samsung S8 into the mix. Once I try to use the S8 as a wifi remote, I get all kinds of disconnects on the S8 and the Harmony app shuts down. The light on the hub also turns red momentarily.
This is the only major issue I have with my orbi system.
(and yes I have the latest firmware everywhere, don't need a reset, etc...)
