taohat
Apr 28, 2018Star
Has firmware auto update been turned off by Netgear?
I have 2.1.3.4 that was manually installed to my RBK53 when it was released as beta a while ago. It has been at least 2 overnights and there has been no auto update. I only got notification of new f...
tagteam
Apr 28, 2018Virtuoso
My system auto-updated from 2.1.2.18 to 2.1.4.10 in the typical fashion (at least in my case); the new firmware will first appear in the web UI and then it will install after an extended idle period, which is usually overnight.
Tnerb123
May 07, 2018Tutor
Yes they disabled auto update in one of there versions. You will need to manually update to the latest if you are not currently on 2.1.4.10. Once off that version, auto updates should be resolved.
