darrenmilkins
Apr 26, 2018Aspirant
Has the Netgear Orbi RBK50 got mac filtering enabled and if so how can i disable it ?
- Apr 26, 2018
Access control option and you would uncheck the Turn access control on to disable the filtering.
Apr 26, 2018Guru - Experienced User
- darrenmilkinsApr 26, 2018Aspirant
Thanks very much, I have unchecked the box and it now says access allowed to all new devices, so I'll give that another go with the device I'm trying to connect!
- FURRYe38Apr 26, 2018Guru - Experienced User
Should help.
