darrenmilkins's avatar
Apr 26, 2018
Has the Netgear Orbi RBK50 got mac filtering enabled and if so how can i disable it ?
  • FURRYe38's avatar
    Apr 26, 2018
    Access control option and you would uncheck the Turn access control on to disable the filtering.
