swellvue
Oct 06, 2020Tutor
Have an RBS50Y that is stuck in "config sync" status and running wrong firmware
I have an RBS50Y that is on the wrong firmware version (Pro Mode) and need to get it back to Orbi mode firmware 2.3.5.32 (currently it is running 2.5.2.104). The status now shows "config sync" and ...
Oct 08, 2020Guru - Experienced User
The most current version of FW available for RBSY is
Firmware Version 2.3.5.32 (Orbi Mode for Orbi)
Firmware Version 1.0.0.52 (Extender Mode for Orbi)
There isn't any recent version to match the RBR.
mitomcua
Jan 09, 2021Aspirant
I manually upgraded from 2.3.5.32 to 2.6.1.40 and got the same issue. It got stuck at config sync. Had to downgrade it back to 2.3.5.32 to resolve the issue. But again the UI keeps showing update failed as swellvue mentioned above.
Not sure if anyone else is having the same issue.
- FURRYe38Jan 10, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update after loading units up with newer FW?
mitomcua wrote:I manually upgraded from 2.3.5.32 to 2.6.1.40 and got the same issue. It got stuck at config sync. Had to downgrade it back to 2.3.5.32 to resolve the issue. But again the UI keeps showing update failed as swellvue mentioned above.
- mitomcuaJan 11, 2021Aspirant
I didn't want to factory reset and started from the scratch. It looks like Netgear has recently released V2.6.1.40 which available for both router and satellites including the RBS50Y. I managed to manually updated the router and RBS50Y and everything looked good since.
- FURRYe38Jan 11, 2021Guru - Experienced User
Glad the new FW worked. Enjoy.
:smileywink:
mitomcua wrote:I didn't want to factory reset and started from the scratch. It looks like Netgear has recently released V2.6.1.40 which available for both router and satellites including the RBS50Y. I managed to manually updated the router and RBS50Y and everything looked good since.
