elliem
Jan 21, 2020Follower
have not been able to use VPN since we installed orbi
The suggestions say to log in and allow for vpn but I cannot even log into the orbi account bc it says i am not connected . The orbi is used to boost our Fronteir wireless service.
Jan 21, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance, If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Log into the RBR with the RBRs log in credentials, which would be admin and the password would be what ever was set during the setup wizard process. Use a PC or laptop with a web browser to connect to the RBR at orbilogin.com or 192.168.1.1 This account differs from the netgear support account.
