bearabl's avatar
bearabl
Have RBR50 and 1 RBS50. Can i hardwire into the satellite make it basically an AP? If so, how?
I have an RBR50 and one RBS50, my house has some rooms that have wired ethernet.  I've been using my satellite wirelessly thinking it wouldnt work as an AP, but after doing some poking around it seem...
  • CrimpOn's avatar
    Apr 26, 2021
    This may be a semantic question.  "Satellite" and "Access Point" are technically different things.
    An Orbi satellite definitely can be connected to the Orbi router with ethernet.  As this Netgear web page shows:
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    Notice that the connection goes from one of the Orbi LAN ports to any of the satellite LAN ports.  So the connection path is:
    Modem to Orbi router. Orbi router to Orbi satellite.
    The problem many people face who have ethernet wires to every room is that their Orbi is not located at the wiring hub, and there in only one ethernet cable connecting the wiring hub and the Orbi router (leaving no ethernet cable to run back to the wiring hub and then connect to the satellite.)
