JJames24
Feb 07, 2018Guide
Have to keep rebooting my RBR50
RBR50 + 2RBS50 Firmware Version: V2.1.2.18 Internet Provider: Xfinity Despite having applied all the latest patches, I keep having to reboot my Orbi - a few times a week to multiple times a day. W...
Oct 24, 2018Guru - Experienced User
Let undue those changes you made first.
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
MicahD wrote:
I followed JJames24 instructions above and it took my downstream speed from 220mbps to 30mbps.
MicahD
Oct 25, 2018Star
Thank you for the detailed response, but most of that is greek to me. Today my iMac is getting 160mbps+, which is still half what literally every other device in my house gets, but is plenty fast.
What I know is: Recently I started losing all internet connectivity on a daily basis, the WiFi signal still existed but suddenly nothing was connected to the internet. Daily reboots for a few weeks now. Turns out this is a common problem with Orbi. Found this thread, did the things JJames24 noted in his post above, and my iMac suddenly dropped to 30mbps while everything else in the house is getting 280mbps or more.
This morning, iMac is back up to a respectable 160mbps. Now just waiting to see if I have to reboot in the middle of the day like I've had to for the past two weeks.
- FURRYe38Oct 25, 2018Guru - Experienced User
Ok. Please give feedback and answers to some of the questions presented if you can. Helps us to know this information.
You can also try this as it seems to have helped other Apple users:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
- MicahDOct 25, 2018Star
Ok great, thank you again! If the rebooting proble persists (or does not) I'll report back here, if it's gone great, if not I'll follow the suggestions you outlined.
Sounds good. Enjoy. :smileywink:
