computersteve
Aug 09, 2019Apprentice
Have to keep Wan on Static... If I don't I get Magenta and loose internet
I am having a very weird problem... I'm on firmware V2.3.5.30. I have Optimum service & I'm noticing that if I leave my Orbi on DHCP wan within a few minutes I loose conecitvity / the orbi switches t...
Aug 10, 2019Guru - Experienced User
Has a factory reset and setup from scratch been performed since the FW update?
computersteve wrote:I am having a very weird problem... I'm on firmware V2.3.5.30. I have Optimum service & I'm noticing that if I leave my Orbi on DHCP wan within a few minutes I loose conecitvity / the orbi switches to detecting internet (Magenta Light)... If I go into the settings then switch the orbi to Static IP using what it obtained from DHCP it works. Thing is I don't pay for static so it is a DHCP service.. Why isn't the Orbi working correctly with DHCP?
