rojo8
Sep 06, 2018Aspirant
Having connectivity issues with the orbit RBK40
I have a Netgear's Modem, Nighthawk X6 been replaced by orbi. First, their support people on the phone suck (netgear). I spent an hour waiting for someone to answer some questions, I simply wanted t...
Sep 07, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
