DarthThomas
Sep 15, 2019Aspirant
Having issues with downloads
Hi, I recently got a RBK50 system with one sattilite. I have hooked up the system and everything is working ok except for my laptop. I am getting wifi on it but I can not do any updates on my window...
CrimpOn
Sep 15, 2019Guru - Experienced User
Can you please describe the situation in more detail. The laptop connects to WiFi. Ordinary activities like email, web browsing, printing, work correctly? Only (1) Windows Update fails with an error code? (2) Kapersky antivirus does not update its database (with an error code?) and (3) IPVanish no longer allows you to reach the resources you use it for,
Or..... You use IPVanish for "everything" and "nothing works."
Thanks
- DarthThomasSep 15, 2019Aspirant
windows update - We couldn't connect to the update service.
kaspersky - doesn't say anything. It just starts then stops
IPV - An error occurred while sending the request.
- FURRYe38Sep 15, 2019Guru - Experienced User
Can you temporarily disable Kaspersky and IPV?
DarthThomas wrote:windows update - We couldn't connect to the update service.
Arris Surfboard SB6183
