Destructormode
Feb 13, 2019Aspirant
Having large lag spikes on WiFi every 10-15 seconds
Good day forums, I finally made the jump to a mesh network last month with the RBK50, one additional satellite, and one plug in satellite. So far it has been great- I have a large old home with thi...
ekhalil
Feb 19, 2019Master
Agree with CrimpOn that it can be some of your attached devices which is impacting the performance of Orbi.
What other wired devices do you have connected to Orbi? Do you have any wired mesh speakers? Any IPTV services?
Destructormode
Feb 22, 2019Aspirant
Ugh, man this is killing me, these 2500 spikes are destroying my expereince.
Connected Devices -
2 Nest Thermostats
5 Nest smoke detectors
1 Ring Doorbell and 3 Ring cameras
1 Smartlock
4 Google Home speakers
1 Apple TV
50+ Smartlights
Important to note, nothing is actually running through a direct connection to the router or satellits, everything is wi-fi enabled. I moved my channel to one that was not occupied by my neighboorhood as well.
- FURRYe38Feb 22, 2019Guru - Experienced User
So, I would try this, factory reset and setup from scratch. This time, set up a different SSID name. This will prevent current wifi devices from connecting to the system. Lets isolate the system from everything else. Wire connect just one PC to the system.
Check for spikes.
Add just 1 wireless device, start with a phone.
Check for spike.
Let us know what you find here. I'm wondering if there are spikes with mimimal devices connected.
You can change the SSID back to what you had been using.
Connected Devices -
2 Nest Thermostats
1 Smartlock
1 Apple TV
50+ Smartlights
