mmolesbr
Apr 02, 2021Aspirant
Having to reboot Orbi RBR50 Multiple times a day (No internet...Wireless Connects)
Firmware: V2.7.2.104 I connected to admin console: 10.0.0.0.1 So I have had my Orbi for a couple years and it has worked flawless until now. What started happening was, i can connect to wire...
Apr 02, 2021Guru - Experienced User
Seems like the .104 firmware has had many issues.
Some have found that disabling the traffic monitor and potentially daylight savings times fixes the issues.
Others have had to downgrade to the slightly older version of the firmware to fix the issue.
I notice you have a different IP address than default. Any issues with double nat?
mmolesbr
I have had no issues with Double NAT. Wife and I use VPN daily, but are not gamers.
- tucsonticoApr 04, 2021Virtuoso
Check out what another forum member just posted regarding 2.7.2.104 firmware.
Orbi RBR-50 dropping internet connection to modem ...
Good Luck!
