thickhead
May 11, 2019Aspirant
Having trouble with setup (RBK50 and Fios Quantum Gateway)
(My model number is actually RBK50/AC3000 - that wasn't an option from the list)
I am trying to install my system. (I bought it 7 or 8 months ago and my several attempts to install it have all ...
SW_
May 11, 2019Prodigy
...just to confirm, please make sure that Fios LAN cable is connected to Orbi yellow WAN (Internet) port. The other 3 LAN ports are meant for local LAN clients.
thickhead
Yes -- appreciate your checking. The ethernet cable goes from Orbi "internet" to fios router LAN. Sigh. I think the answer lies in what you originally said about the conflict -- if I can just find a way to get to the page where I can change the orbi to AP mode, I think the problem would be solved. I'll keep working on it. Thanks!
- SW_May 12, 2019Prodigy
thickhead, please login into fios box and find out what IP address it assigns to Orbi. SInce there are only two clients, one is your client and the other is Orbi. Then point the browser using that IP address.
For example, if the Orbi IP address is 192.168.1.2, then point your browser to it. You can also use brute force if you can't find out Orbi IP address from Fios. The Orbi IP address is within this range: 192.168.1.2 to 192.168.1.254.
Alternately, please disconnect all LAN cables from Orbi, including the WAN port. Turn off all Satellites. Use a paper clip to do Factory Reset the Orbi. Next, connect to Orbi wirelessly. Orbi should be back to default, Router Mode, which is the same as if it came out of the box for the first time. Then you should be able to use its dns name, orbilogin.com, for setup, just skip the steps for setting up all the Satellites. Now you should be able to switch Orbi to AP mode. Once you are done, turn off Orbi, turn off Fios, connect its WAN port to the Fios, turn on Fios, and finally turn Orbi back on. Check if you can access the internet via both Orbi LAN and WiFi connections.
- thickheadMay 12, 2019AspirantThank you - I will try that. I appreciate your patience.
