thickhead
May 11, 2019Aspirant
Having trouble with setup (RBK50 and Fios Quantum Gateway)
(My model number is actually RBK50/AC3000 - that wasn't an option from the list)
I am trying to install my system. (I bought it 7 or 8 months ago and my several attempts to install it have all ...
thickhead
Yes -- appreciate your checking. The ethernet cable goes from Orbi "internet" to fios router LAN. Sigh. I think the answer lies in what you originally said about the conflict -- if I can just find a way to get to the page where I can change the orbi to AP mode, I think the problem would be solved. I'll keep working on it. Thanks!
SW_
May 12, 2019Prodigy
thickhead, please login into fios box and find out what IP address it assigns to Orbi. SInce there are only two clients, one is your client and the other is Orbi. Then point the browser using that IP address.
For example, if the Orbi IP address is 192.168.1.2, then point your browser to it. You can also use brute force if you can't find out Orbi IP address from Fios. The Orbi IP address is within this range: 192.168.1.2 to 192.168.1.254.
