jzsgold
Aug 22, 2020Tutor
Hayward OmniLogic HLWLAN not connecting to Orbi RBR50 Network
Have Orbi RBR50 with 2 Satellites. Installed Hayward OmniLogic with HLWLAN bridge. Unable to establish connection the bridge with Orbi network. HLWLAN sees network and able to enter pw but OmniLogic ...
- Sep 03, 2020
SOLVED. So I set up the network to connect to an AirPort Extreme as an AP on the Orbi network and set it for 2.4 MHz only. But I think the main part of the solution was that Hayward sent me a new HLWLAN unit and it connected. The error message about the antenna not connecting was the bridge itself. So if your getting a connection error message about the antenna your HLWLAN is bad. But during this process I heard that the HLWLAN doesn't like the Orbi network. Hope this helps you.
