Tmccone
Jul 12, 2019Follower
Heat tolerance
I’d like to place an Orbi satellite in my attic. Will temps up to 115 hurt that unit?
CrimpOn
Jul 12, 2019Guru - Experienced User
My advice - don't.
Environmental specs for indoor Orbi units appear to be 32F to 104F. The external RBS50Y has specs of -4F to 122F.
- I doubt that a typical attic will top out at 117F unless the house is in a really "temperate climate". In the summer, attic temperatures soar much higher than that.
- How will electrical power get into the attic?
- At least 50% of the antenna coverage will be "outside", i.e. not directed toward likely users.
There is probably a specific need that led to this question?
