mmaso01
Mar 29, 2021Tutor
Help - Losing Orbi50 connection
I have an Orbi50 and a satellite. Been working well for over a year. This week, I started losing connectivity a few days a time. Firmware ver. 2.7.2.104
The Orbi is plugged into my modem (the way it has always been). My PC is plugged directly into the orbi via ethernet. I also use wifi througout the house.
What ends up happening is that I lose connection on my pc - no internet. It feels like the orbi goes to sleep. If I go into the admin page on the orbi and run a "test" on the internet setup page, the internet comes back!!
Any ideas?
Thanks.
did you try the steps I recommended. after disable dst and traffic monitor, reboot the router.
Sort By
Theres been a few posts with issues with that firmware.
What you could try first would be to disable daylight savings time option and the traffic meter.
If that doesn't help, try a factory reset and reinstall.
If that doesn't help, I'd try downgrading that firmware.
- mmaso01Tutor
Will do, thanks. It just started and nothing has changed. It is confirmed - I lose it 2-4 times per day and running the "test" in the settings seems to bring it back. This is getting old really fast.
- mmaso01Tutor
Running on four days now without going down! Your tips did the trick I believe. For future readers, I simply disabled daylight savings time option and the traffic meter. I did not do a factory resent or reinstall or downgrade the firmware. So far, so good.
Thank You!glad it worked for you!
