madobe
Jun 07, 2021Aspirant
Help - Orbi outdoor satellite issue
I have an Orbi mesh system connected to a TP Link Archer VR600v modem router (has VoIP phone connected) with wifi disabled. I have Orbi RBR20 with 2 x RBS20 satellites indoors. I have 2 outdoor satel...
madobe
Jun 10, 2021Aspirant
Decided to do one last try.....still no luck...
Interestingly,I checked the logs (not done that before) see below:
The MAC address is the one Im trying to connect and sync.
[admin login] from source 10.0.0.22, Friday, June 11, 2021 08:52:25
[WLAN access rejected: incorrect security] from MAC address 3e:80:88:fe:68:68, Friday, June 11, 2021 08:49:57
[WLAN access rejected: incorrect security] from MAC address 3e:80:88:fe:68:68, Friday, June 11, 2021 08:48:51
[WLAN access rejected: incorrect security] from MAC address 3a:80:88:fe:68:6b, Friday, June 11, 2021 08:44:40
[WLAN access rejected: incorrect security] from MAC address 3a:80:88:fe:68:6b, Friday, June 11, 2021 08:44:31
[admin login] from source 10.0.0.22, Friday, June 11, 2021 08:36:04
I'm no tech wizard, maybe something simple someone can suggest?
CrimpOn
Jun 10, 2021Guru - Experienced User
That is really goofy. The MAC address of both of my satellites (RBS50 and RBS40V) both come back as "Netgear".
This MAC address comes back as "No Matches"
https://www.wireshark.org/tools/oui-lookup.html
I have no idea what else you can try.
