stewlevine
Jan 09, 2021Aspirant
Help changing an RBS50 from wired backhaul to wired backhaul
I have an RBK53 system running in AP mode, router and satellites are running firmware 2.5.2.4. My satellites are currently connected over wireless backhaul, but I have run cable and would like to mig...
alokeprasad
Jan 10, 2021Mentor
I haven't used ethernet wired backhaul. So, I'm of not much help here.
Most people connect the RBR and RBS directly with the ethernet cable. Do that first to see if the wired backhaul works.
Then, the question on the table is whether the RBS can have switches between it and the RBR? Hope someone who has tried this will chime in. In fact, can the RBS be hangng off the wired network across the building with any Ethernet topology between it and the RBR?
- GMoGoody8Jan 10, 2021LuminaryI have been following this topic since the summer as I was building my home, and my Orbis would be able to have access to home runs to one switch. The consensus I saw over the summer is that most people could only get Ethernet backhaul working with switches that didn’t support or could turn off the Green Ethernet Standard (802.3az).
I’m not sure if that is still the case on newer firmwares. I’ll personally be testing this in 10 days myself. All my switches unfortunately support 802.3az.
