SubyBrue
Sep 30, 2019Aspirant
Help Changing Orbi from AP back to Router (Verizon AP mode to Comcast Router)
I have successfully been using my Orbi system (RBK23) in AP mode when I had Verizon and was using their Quantum Gateway (turning off their Wifi and everything going through the Orbi's Wifi in AP mode...
Sep 30, 2019Guru - Experienced User
Log into the RBRs web page with a web broswer and navigate to Advanced tab/Advanced Settings/Router_AP mode. Here is where you can select Router mode. Save settings.
- SubyBrueSep 30, 2019Aspirant
I realize it must be that simple but is it normal not to get the remote admin to display or even connect when the Orbi can't connect to the internet?
- CrimpOnSep 30, 2019Guru - Experienced User
When the Orbi is in AP mode, it depends on a router being available to provide IP addresses for itself and every other device. The new modem is not a DHCP server, so it does not provide IP addresses. Since you mention "remote admin", are you using a smartphone or tablet to administer the Orbi?
If so, you can open a web browser (not the app) on your WiFi device and connect to "orbilogin.net". The Orbi WiFi is set up to look for that request and connect to the Orbi itself. Then, you can enter the login information, "admin" and the administrative password. Navigate to the Advanced Tab->Advanced Setup-> Router/AP mode. Make the change and the modem will restart and work great.
You are never "locked out". You can always perform a "factory reset" and the Orbi will be ready for a fresh setup.
Yes I am trying to go to Orbilogin.net from a laptop computer (not the app). Either way I cannot get into the management console to make this flip. The SSID is broadcasting but will not allow me to connect to the console (on my laptop and iPad is says "no internet" under the SSID connection name. Web app won't let me do squat on the iPad and laptop takes me to a page saying it cannot connect.
