jp104
Feb 21, 2019Tutor
Help changing Orbi to AP
Recently purchased an Orbi wifi extender and set it up. It worked great for 3 days then I started getting the dreaded 401 error. After searching on the net for this error I see that the way most peop...
- Feb 21, 2019
You can set up the Orbi if you disconnect it from the ISP modem.
Factory reset the Orbi and skip the setup wizard. Once your in, go in to the advanced settings and change the Orbi to AP mode. Then you can connect it to the ISP modem.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
jp104 wrote:
Thank you! I think I have that double NAT thing going on. I'm away from the router now while at work so I'll have to try what you posted later on tonight. Also do you know if there is a way to set the Orbi to AP while doing the set up? I may just have to uninstall the whole thing and try again from scratch.
CrimpOn
Feb 21, 2019Guru - Experienced User
The 401 error appears during random web browsing or specifically when connecting to the Orbi?
If the Orbi login is the only thing affected, then either the Orbi's IP address is not where orbilogin.net typically points to (192.168.1.1) or the login credentials being entered are not correct.
Can you point a web browser to 192.168.1.1 and see if you can log in? If not, do you get this error message:
401 Unauthorized
Access to this resource is denied, your client has not supplied the correct authentication.
